Cost of PUR
6/23/19
Bob
We are thinking of testing PUR Glue on our holz her bander.
I can't find much info about the added cost of running PUR.
I know you use less so just looking at glue pricing wont help.
Can anyone shed some light on this subject?
6/23/19       #2: Cost of PUR ...
Sam Jackson
We have an SCM banded capable of running pur in pellet form. I’ve found the glue itself to be amazing. But (there’s always a but) it takes us about 1 hour to switch over. Heat up time, purging the cleaning agent, etc etc.
Also if you are going to pellet route: the have a extremely short shelf life. After opening, the jowat we use has a shelf life of about 5 days. Do NOT use it after that. Almost bricked a glue pot. Check the expiry date of the glue too. Don’t accept glue from a supply if it’s going to expire in 4-6 months.
In addition I would strongly recommend having a small chest freezer on hand. If you have power outage or something, you can pull the pot and store in the freezer until you are back up. Hope that helps!
6/24/19       #3: Cost of PUR ...
Bob
What about cost difference?
Is glue cost more than twice as EVA?
8/23/20       #4: Cost of PUR ...
Doug Member
If it helps we find we get around 80m from a 600gm sachet of pur pellets. The setup time and risk is probably worth as much as the glue unless you're doing long runs.
I understand holzer is easier for PUR but the scm had better overall features and service so we went that way.
