Woodtek Wide belt sander Felt for Platen
7/15/19
Nick Cook Member
Hello,
I fixed my drum, thanks to the suggestions I received on the forum. Now I'm having a hard time finding a dense felt to use under the graphite on the platen. Is there any material that I could substitute for the felt? The felt I found locally is too soft.
7/15/19       #2: Woodtek Wide belt sander Felt for P ...
TonyF
Nick Cook:
I'm guessing that you can't contact the manufacturer or their parts supplier, if they are still in business.
If that is the case, and you have some idea of what you need, McMaster-Carr has a lot of industrial products that meet many requirements.
Hope this helps.
TonyF
Felt
7/16/19       #3: Woodtek Wide belt sander Felt for P ...
McMaster has "everything", if they don't they can get it. If you call they will also get the felt manufacturer on the phone and they can help. It is truly amazing.
7/23/19       #4: Woodtek Wide belt sander Felt for P ...
Nick Cook Member
That site is great. Does anyone have a recommendation for the firmness I should be looking for. The felt comes in a variety of firmness specs.
7/23/19       #5: Woodtek Wide belt sander Felt for P ...
TonyF
Nick Cook:
If you are timid about ordering from McMaster-Carr, you might try ordering the felt from some other widebelt manufacturers parts list, as I imagine that they are all similarly sized and have similar density specifications as well.
You can use a Chevy bolt to hold down a Ford part, even though the dealers will tell you otherwise.
TonyF
7/24/19       #6: Woodtek Wide belt sander Felt for P ...
Adam West  Member
Usually the best off the shelf felt is F1 pressed. I like firmer material but for most machines the F1 is decent.
    Lamello
