Compressor advice
11/2/19
Harold
We have had a 5 hp 60 gallon vertical compressor by ingersol Rand with a seoerate air dryer from harbor freight for several years. We are moving to a bigger space and this compressor has seen better days. Large Brandt Bander and double line boring machine. No spray booth and one slider with a pneumatic tiger rip fence. Other slider is electric. 3 assembly stations with usual nailers. Any recommendations for a bigger compressor without breaking bank?
11/3/19       #2: Compressor advice ...
Horsepower and tank size is a poor way to know what air you have available now. Sizing a compressor is a matter of looking up the max air consumption of all the tools and machines that may run at the same time. It may be as simple as changing the compressor to a two stage on what you have. Shouldn't need that much larger since you have no air sanders and no spray booth. Those are the big air hogs. Put in large diameter air lines in the new space and you gain storage capacity.
11/3/19       #3: Compressor advice ...
What I have has nothing to do with what you need. I'm just offering up an idea. I have a 15hp Atlas Copco with the dryer built in. It's 53 cfm at 125psi.
If I were to do it again, I'd do 3 smaller separate compressors, with a separate line dryer.
Why? Most of the time, 10-15cfm is adequate. I'm spending a bunch of money spinning over a larger than necessary motor most of the time.
Also, we have just the one compressor. It goes down, so does the shop. Having multiples adds some redundancy. Plus if you had to, you could likely take one offline to do maintenance too.
I'd set one to kick on at say 115psi, the second at 110, and the last at 105.
Same amount of air, more safety from breakdown, less juice being used. Plus you can scale it and increase capacity if you need to.
Downside? Three compressors cost more up front.
5/8/20       #4: Compressor advice ...
Al Gerhart Member
I have been using the cheap five hp compressors for years. Set up two so when one goes down you can still work. Buy an extra compressor head while you are at it and put it in the tool room to swap out when one of the machines goes down.
Run some 3/4" copper airlines around the shop, costly but you would be amazed at how much more air is available due to storage and less friction. Put some blow out valves at the ends of all runs. The harbor freight dryer/filters will do the job, one at each compressor, one in front of the spray booth, hardly anything gets past the first filter anyway.
Years ago I was running a 30 hp compressor that would cost $1000 to rewind the motor when it went down. Finally figured out that the back up 5 hp cheap compressor was more cost effective and given a good loop large diameter piping system two of the smaller units would do everything we needed. Figured out that air drills were cheap to buy and expensive to run and didn't need that kind of air volume anyway.
