Bi-Fold Doors for TV cabinet
1/31/20
Chris
I have a TV cabinet to build on the wall the client wants bi fold doors. There don’t seem to be much options out there. Need help please.
1/31/20       #2: Bi-Fold Doors for TV cabinet ...
Just bi-fold or bi-fold pocket doors? If just bi-fold, just use butt hinges. No magic required.
2/1/20       #3: Bi-Fold Doors for TV cabinet ...
Paul Miller
If its is just Bi-fold, Salice has a system, Concertina that works really well. If it is Bi-fold and pocketing, Hafele has a system, Hawa. The Hafele system is expensive, thousands of dollars and it is very difficult to install. We have used both.
2/1/20       #4: Bi-Fold Doors for TV cabinet ...
duster
Website: http://sunvalleywooworks.com
I've done quite a few TV cabinets with bi-folding doors, most were also pocket doors. As Rich says, butt hinges work fine for the bi-fold, mounted on the back of the doors. I normally use non mortise hinges, 2 or 3 depending on the height.
If they also need to be pocket doors, there are several options. If your doors are 3/4" thick, the Accuride 1332 slides are not expensive, fairly easy to install, and work well. They use a length of cable wrapped around a couple of pulleys to prevent racking when the door is extended or retracted. That's what I used for the piece on the photos. If your doors are thicker and/or heavier, the KV rack & pinion slides are a good choice. They do take twice as long to assemble and install as the Accurides.
I haven't used the Salice or Hafele hardware that Paul mentions. I've had good results with both the Accuride and KV systems, no call backs in the 20+ years I've been using them.
View higher quality, full size image (1100 X 744)
View higher quality, full size image (1100 X 733)
2/2/20       #5: Bi-Fold Doors for TV cabinet ...
Chris
Duster
What you show here is what I want I also ran this on another form and a guy was showing me the same thing that you have done. This is my choice I am going with. I may check out the acuride I believe they will be less money then the KV that he used although his KV has 2 hinges top and bottom. Thank you so much.
2/2/20       #6: Bi-Fold Doors for TV cabinet ...
duster
Chris - keep in mind that the Accuride & KV slides are not full extension, you lose about 4" of travel no matter what length slide you choose. The width of the bi-folded doors and the interior depth available in your cabinet are important to factor in when choosing the length of slide to use. I've had to make tri-folds a few times because the cabinet was not deep enough for the slide length needed for a bi-fold.
2/2/20       #7: Bi-Fold Doors for TV cabinet ...
Chris
Yes that is going to be a problem right now the doors are going to stick out about 5” unless he lets me make the cabinet a few inches deeper it’s going to hang on the wall not have no floor support so he is not wanting it very deep.
2/2/20       #8: Bi-Fold Doors for TV cabinet ...
Chris
He was wanting bi fold doors that way the whole door would be sticking out in the way you couldn’t see the TV unless you was right in front of it. So at least I can get the most of the doors hidden.
2/4/20       #9: Bi-Fold Doors for TV cabinet ...
A bifold door would lay back parallel to the cabinet face. It won't block viewing of the TV.
2/5/20       #10: Bi-Fold Doors for TV cabinet ...
When wall mount TV's arrived, I did several cover-ups for designers.
These were 4 doors, conventional butt hinges in a bifold configuration.
The cabinets were shallow - 4-6" deep. When built and set, they were 3/8" deeper on the bottom than the top. This caused the doors to either lay flat in the cabinet (inset or overlay), and to fold open and lay back parallel to the wall. No magnets, no catches, nothing but physics.
