Soft v hard maple for doors
2/11/20
Tadhg
Hi guys I have make solid maple shaker doors for kitchen project But there is lot steam heat risers in 3 corners of room
The kitchen is small 14 x 10 with a 6 x 8 wing at one end. I’m worried bout doors twisting with amount heat as it’s face framed and wonder which is best maple to use soft or hard.
Which will be best option keep doors true and straight
Any help greatly appreciated thanks tadhg
2/12/20       #3: Soft v hard maple for doors ...
We have used soft maple exclusively for paint grade casework & kitchens for 30 years. We have never had any issues in kitchens or baths. We have primarily used waterborne finished since 2005.
The one issue I could foresee is the soft maple. Apparently there are different trees labeled soft maple. I have no idea which ones we get. Hard maple is one species.
2/12/20       #4: Soft v hard maple for doors ...
We did soft maple for quite a while for door sticking, and have switched to beech. Seems to be a little more stable and it comes off the rip saw a little straighter.
We don't have a moulder to do any straightening, and face/edge jointing each piece doesn't fit our price point.
I think the beech is an improvement, but not a massive one.
2/12/20       #5: Soft v hard maple for doors ...
Tadhg
Thanks guys I might try making stiles 2 1-2. And doors. 1 1/16 thick thanks for all advice. T
2/12/20       #6: Soft v hard maple for doors ...
Matt Calnen
I use quartersawn hard maple for my high end work, and large cabinet doors. It’s a lot more expensive than regular hard maple, but that expense as it relates to the overall cost of the job, is not much, and money well spent in my mind.
2/12/20       #7: Soft v hard maple for doors ...
Tadhg
Matt I have no problem paying more for quarter sawn. It’s money well spent if I don’t have any callbacks when doors and frames are finished. Have you had good success with this. Thanks for all reply’s guys this great forum T
2/14/20       #8: Soft v hard maple for doors ...
Quartersawn material is definitely a good idea. 👍🏻
2/28/20       #9: Soft v hard maple for doors ...
dan summerhill Member
We use all soft maple but we are methodical. One problem I would balk at is your thickness. Remember that more wood means more moisture means more potential for movement. Get a little thinner if you can. We mill our parts from rough 5/4 lumber. We do 2 1/4 R/S so we rip to 2 1/2 and then chop 4" long. Joint the face flat and one edge. Skip plane them. Stack them on edge with 1/2"-1" between for air flow under forced heat overnight. If they move a little, use them for short rails. If they move a lot, can 'em. If wood hates you, it will always hate you. We yield 7/8 to 1" depending on profile.
    • Better Vacuum Cups, Inc.
    • Biesse America
    • CP Adhesives
    • Impact Search and Placement
    • Template Services
