.018 PVC Outside Radius
2/24/20
MarkB Member
Can anyone give me a heads up on how tight you would ever push .018 x 1 3/4" PVC banding on an outside corner? Was hoping to avoid heat. This would be applied manually with contact most likely.
2/24/20       #2: .018 PVC Outside Radius ...
Ex-Pat Member
.018 PVC is pretty flexible, I don't think there is an outside radius that would make me nervous. You can pretty much fold the stuff around a 90 degree corner. Steel roller and plenty of force, you should be fine.
2/24/20       #3: .018 PVC Outside Radius ...
MarkB Member
Thanks,
I have plenty of 15/16 and same conclusion, I can wrap it around a pencil. My concern was some long term butt-biter that I wasnt forseeing.
Much appreciated.
2/24/20       #4: .018 PVC Outside Radius ...
Matt
It is flexible, but speaking from experience this can be tricky to get to press flat enough on both sides. In other words, when using contact adhesive on an outside corner, it's easy to have an open joint. Same thing with an inner radius.
It can be done well but getting it totally closed up will require intentional effort.
2/24/20       #5: .018 PVC Outside Radius ...
MarkB Member
Matt,
This is an issue with HPL even on allowable radius' which is why Im asking. The radius is going to be in the 3/4" range so not the nightmare of a pencil.
    • Better Vacuum Cups, Inc.
    • Biesse America
    • CP Adhesives
    • Impact Search and Placement
    • Template Services
