fancy hinge mechanism
3/30/20
Barry Member
I can't find the hinge mechanism that I want as I don't know what it is called so google is a bust. I want to install a hidden desk below a window (high window sill that used to be the kitchen) where, when hidden vertically, the top is pulled out and becomes the front of the desk, and the bottom slides straight up and becomes the back of the desk. This means that the desk surface is hidden within the cabinet, allowing some way of holding the keyboard and mouse on it and folding it away.
There must be a mechanism on the market that allows this to happen?!?! But I can't find it!!
Help!!
3/31/20       #3: fancy hinge mechanism ...
I vaguely understand this. I would first make a drawing showing sizes, weights etc, etc. Then check with Hafele or Richelieu. They both have some interesting pull-out, fold down, fold up, flip up or down slide in or out push over or under fancy hidden hardware for tabletops and counter extensions.
Stay safe out there
3/31/20       #4: fancy hinge mechanism ...
Barry Member
Thanks Dennis, I have already trawled through every hardware site I can find to no avail.
3/31/20       #5: fancy hinge mechanism ...
Barry Member
A garage door isn't a million miles away from the action I am looking for.
3/31/20       #6: fancy hinge mechanism ...
Barry
I don't really understand what you're looking for or if it exists, is it similiar to a flipper/pocket door?
3/31/20       #7: fancy hinge mechanism ...
Ex-Pat Member
If you could post a drawing of what you are trying to accomplish we'd be more apt to give you some pointers. By your description I am having a bit of a hard time visualizing it.
3/31/20       #8: fancy hinge mechanism ...
It's not this is it? I built that desk they used in the photo for the catalog.
https://www.rockler.com/federal-desk-plan-and-desk-support-hinge-set
