Lazy Susan
4/16/20
The last time I did one of these where the doors rotate with the lazy susan it was a PIA to get it adjusted, the customer insists on this type.
Is there a good way to do these?
Pat
4/16/20       #2: Lazy Susan ...
Redneck
A easier Job would be, pulling teeth from pack of rabid Wolves! Just saying!
4/16/20       #3: Lazy Susan ...
I use to do these a lot. They suck. I remember the 1st time I did one not connected to the doors. I couldn't believe I was done with the installation it was so simple.
If they want that and you can't convince them otherwise, charge them up the wazoo for it.
4/16/20       #4: Lazy Susan ...
D_A_YOUNG_ONES_GET_ME_OFT_PISTE
I have to agree with Leo on this except, it should be a minimum of ^9 of your standard rate, just for good measure if nothing else... GET PAID FOR WHAT THEY DON'T KNOW... KNOW WHAT I MEAN????
4/16/20       #5: Lazy Susan ...
Ok duly noted and thanks for the input and BTW Redneck what is the going price for dental work on a rabid wolf?
4/16/20       #6: Lazy Susan ...
mike
Website: http://distinctivekb.net
A cabinet builder friend who hates doing anything special told me he uses the Hafele Susie Q with fold in doors. I have not used that unit but I have used quite a few of the Safety Susans. link below. Still a little finicky to install from the back but a rock solid unit.
http://www.westearl.com/safetysusan.html
4/17/20       #7: Lazy Susan ...
D Brown
Remind the clients that if anything falls off the susan it is next to impossible to retrieve it. Show them what a super susan by revashelf looks like.
4/17/20       #8: Lazy Susan ...
KCR Member
Have you tried offering a diagonal front corner susan? I refuse to do any type of pie cut susans. I only offer diagonal front susans. If a pie cut susan fits into a corner so will a diagonal susan. They offer more usable shelf space for the customer and are the same door type installation as all other doors in the kitchen. I also find it simple to add a drawer in above the susan when drawer space is at a minimum and they are also easy to install. Sell it on the obvious benefits.
4/17/20       #9: Lazy Susan ...
Thanks again guys, I was able to sell her on using the open the door then access the susan shelf type of setup
4/21/20       #10: Lazy Susan ...
Jim brady Member
Never liked 2 door swinging from corner.first doors to break
    • J&P Machines
    • CabMaster Software
    • Lignomat
