Panel Genie
resurfacing cabinet doors
6/28/20
ennisdavis Member
Is it possible to remove plastic laminate from existing particle board cabinet doors without destroying them. Most cabinet shops never do this, they just use new MDF. Dont want to laminate over the old stuff either.
6/28/20       #2: resurfacing cabinet doors ...
Particleboard is dead cheap. Why waste labor? The customer will appreciate the smaller bill of starting with new sheet stock.
6/29/20       #3: resurfacing cabinet doors ...
You can strip off the laminate with acetone but as rich says, seems a lot of work. Assuming your trying to just replace the outer face and edges but....
6/29/20       #4: resurfacing cabinet doors ...
MEK (Methyl Ethyl Keytone) is better than Acetone. Wear protection.
6/29/20       #5: resurfacing cabinet doors ...
Mark
If you're doing one or two maybe.
Still easier to just cut new door blanks.
6/29/20       #6: resurfacing cabinet doors ...
We always used lacquer thinner for removing plam, it was mainly used when a mistake was made on plam projects. The glue we used was 3m water base, so the lacquer thinner worked really well, but it still left a lot of the softened glue on the work piece, which was a lot of work to clean up. I am not sure how it would work on older solvent based contact cement that has been sitting for a long time.
The guys in this forum like Rich and Mark have given you some excellent advice, it will be a lot cheaper to buy and cut new cores then to remove the laminate and clean the old ones.
6/29/20       #7: resurfacing cabinet doors ...
pat gilbert
Another vote for buying new PB.
If you use solvent to take off existing laminate there is a good chance that the solvent will wick back out delaminating the new laminate.
6/29/20       #8: resurfacing cabinet doors ...
MarkB Member
Stripping the laminate off sucks period but its not uncommon (of course always avoided) to remove a bad/broken with solvent. All solvent sucks, but MEK as Leo mentions, or Acetone, will not be there for long. They will be gone in no time. I avoid the MEK, not that the Acetone is any healthier. Lacquer Thinner is too slow and definitely does leave a bit of residue behind.
I cant imagine stripping a face and edges off a set of doors and fronts that way, but..
6/29/20       #9: resurfacing cabinet doors ...
ennisdavis Member
Wont the solvents get into the wood and cause warping or other problems. These doors are wide and I am not setup for a sled on my table saw. Some people laminate over laminating, how do you guys feel about that.
6/29/20       #10: resurfacing cabinet doors ...
I feel it's going to make the door wider, taller and thicker.
6/29/20       #11: resurfacing cabinet doors ...
Not sure what kind of professional shop you are running, but not even having a sled on a table saw must make profits really thin!
6/30/20       #12: resurfacing cabinet doors ...
scott brady
Save yourself the headache literally, order laid up panels for almost the same cost as your price of laminate and with a hard glue line. Cut , band, hinge and be on your way with no call backs on delaminating new plastic.
7/1/20       #13: resurfacing cabinet doors ...
Bruce H
getting laminate off doors will depend on what glue was used in the first place. Mine are cold pressed, it's not coming off with MEK or any other solvent. Unless you are a home owner doing it yourself with no time value the effort to remove laminate would far exceed new material.
7/1/20       #14: resurfacing cabinet doors ...
pat gilbert
One other thought
The cost of laminated sheets is usually less than if you buy the material loose.
7/1/20       #15: resurfacing cabinet doors ...
Jim Kolar
Yes you can but some skins will break free easy and some won't. If these are layed up panels with a press you won't get the laminate off.
7/2/20       #16: resurfacing cabinet doors ...
ennisdavis Member
I agree with you guys, new material for the doors but I really want to use 5/8" MDF and its impossible to get. For kitchen cabinet doors 1/2" wont cut it and 3/4" is too beefy.
7/2/20       #17: resurfacing cabinet doors ...
pat gilbert
I have found that although hard to do, the most efficient thing to do is Change Your Mind
7/2/20       #18: resurfacing cabinet doors ...
Your industrial sheet goods supplier doesn't have 5/8? You need to find a new supplier!
7/3/20       #19: resurfacing cabinet doors ...
ennisdavis Member
I use a major US supplier, just the local one has a hard time getting 5/8" needs to be ordered.
7/3/20       #20: resurfacing cabinet doors ...
ennisdavis Member
Speaking of MDF, I have been reading about alot of people having screw pull out on hinges, they are using plastic dowels. Is this common.
7/3/20       #21: resurfacing cabinet doors ...
Alan F.
Use 11/16" core, VG laminate with CL or VG back and you get a slightly less than 3/4" thick panel.
If you want to re-laminate in the field use something like Wilsonart Recover, it is peel and stick and designed for re-laminating in the field
WILSONART® RE-COVER™
7/5/20       #22: resurfacing cabinet doors ...
Why do you want to use mdf? I would use particle board, it is way cheaper, lighter, adhesive sticks to it better and like others said use the inserts with your hinges. You can get a pb core that is around 11/16 thick, works wonderful for laminate and veneers.
What kind of edgebander do you have?
The production shops glue up sheets , cut it and then run it through the edgebander.
You need a decent edgebander for this process. If you are only doing a few jobs like this or don’t have a good edgebander I would Edge the presized panels first and then glue the faces. It is a lot more labour , but if you are using a laminate trimmer it is way easier to get a good job this way.
7/6/20       #23: resurfacing cabinet doors ...
ennisdavis Member
MDF is more stable due to the resin content, flatter and more water resistant then PB. The edges on PB is lousy, porous and rough. $19 for a 4x8 sheet of MDF 5/8, can you get cheaper then that?
7/6/20       #24: resurfacing cabinet doors ...
In reply 16 you said 5/8 MDF was impossible to get. Now you are shopping for price? What gives? Seems like you would be thrilled you found it at that price!
7/7/20       #25: resurfacing cabinet doors ...
ennisdavis
It was a figure of speech. I can order it, not that convenient. It is a great price.
7/11/20       #26: resurfacing cabinet doors ...
Jeff
With your comments about mdf vs pb it is obvious you are new in the game of plastic laminate work.
With all your comments it sounds like you are just building this for your garage or basement storage room, so I guess it doesn’t matter what you use.
    Lamello
