Tip-on or servo-drive?
8/10/20
Michael Sanders Member
I have a job coming up that is designed without pulls. I'm looking for opinions on Blum's tip-on vs their servo drive. I have used tip-on a few times and i'm not convinced it is the best way to go in a kitchen where the client will use the drawers daily. I like the fact that tip-on is purely mechanical and requires no power, but it seems like you have to hit the drawer face in the right spot for it to open, and sometimes the drawer will bounce back out if it is not closed with enough force. I have never used the servo-drive system. What can others say about its functionality and long-term reliability?
-Michael
8/11/20       #3: Tip-on or servo-drive? ...
Servo drive is nice. Servo drive is expensive. It has the advantage of a very light touch and no bounce as the tip on does.
Sized correctly the tipons do nicely. You have to make sure they are adjusted properly for good operation. By playing with the in/out adjuster you can usually get them to work nicely.
I never use the lightest size anymore, just not enough push. But that makes it so you have to give an extra push to make sure they don't bounce when they close.
If money isn't a issue servo is nice.
8/11/20       #4: Tip-on or servo-drive? ...
Matt Calnen
I had a similar situation this past winter. I tried Grass slides and their tip o matic opener. Worked good and has built on weight adjustments for the drawer so you can dial in the function so it’s easy to use
8/12/20       #5: Tip-on or servo-drive? ...
chris
Tip on with Tandem works pretty well BUT sometimes you get a clicking sound because some minute compounded issue such as a combination of an out of square drawer box or twisted drawer box or one slide is set slightly higher than the other or locking device not fully seated or out of plane to bottom of drawer or etc etc.
We've done maybe 100 and out of those have had this issue maybe 5 times. adjusting the tip on wheel is critical as is the slide set back from edge of case (we have a little plastic orange thing the blum rep gave us).
Never done servo so can't say. I will say that the legrabox with tip on seems fussier than a wood box for some reason (clicking sound again when pushed to open)
Ive heard that Tip on for tandem is going away and will be replaced by Movento. We have done both...click still persists sometimes
10/22/20       #6: Tip-on or servo-drive? ...
Michael Sanders
Thanks for the responses guys! I ended up making a two drawer mockup cabinet for my client to try out. One drawer servo, one drawer tip-on, both legrabox. The servo drives came out to a job wide average of about $160 more per drawer, truly very expensive. The client originally balked at the cost, but after I sent them home with the little mock up cab, we are doing servos in their kitchen, tip-on throughout the rest of the house. On another note, this our first time using legrabox, and I am really digging how they come out. Just click the face on, and your basically done. So much easier than attaching face to maple drawer boxes.
    Lamello
    • CabinetCRUNCHER
    • GreCon
    • Original Saw Company
      Industrial Radial Arm Saws
    • Impact Search and Placement
