Holzher Sprint Groans
8/28/20
Hello,
I have a Sprint and it makes a groaning/combo slight vibration sound when the part gets to the top/bottom trimmer. Is this a common problem to diagnose? This is a used but new to us bander.
Thanks for any help.
8/30/20 #2: Holzher Sprint Groans ...
Website: http://www.richmondcabinet.com
Remove the rollers that press on the top of the part and clean the bolt that they turn on. Dust collecting on them can cause the groan.
8/31/20 #4: Holzher Sprint Groans ...
Take the front cover off and inspect the drive chain. The lubricating system is questionable. Sometimes you need to add grease to the chain manually, on link at a time.
9/3/20 #5: Holzher Sprint Groans ...
Hi Nick,
We had this same problem with our Sprint and, thankfully, it was an easy fix. It was hard for us to determine whether it was the top or bottom trimmer. It was the bottom. The post arm that supports it from the frame has a spring tension that keeps the trimmer against the edge of the board. It just needed slight tightening to hold it solid against the edge to keep it from vibrating. That totally cleared the problem up for us. I can't remember the procedure but Eddie or Gordon would be able to walk you through it.
9/4/20 #6: Holzher Sprint Groans ...
Hey guys thanks for all your help. I'm trying all these fixes on Tuesday. I love the Woodweb.
