Brad nailers-Senco 25XP vs Bostitch combo brad nailer/stapler
10/20/20
Jim
I'm looking to get an 18 ga brad nailer. Do you have a preference for Senco vs. Bostitch? In particular, I was looking at the Senco Finish Pro 25XP or the Bostitch combo brad nailer/finish stapler. I was intrigued by the Bostitch because of the combo tool. Does anyone have experience with Senco vs Bostitch and the combo unit? I noticed the Bostitch is cheaper than the Senco.
https://www.bostitch.com/products/tools/construction-tools/nailers/finis
h-and-brad-nailers/combo-brad-nailer--finish-stapler-kit/sb-2in1
https://www.s
enco.com/tools/details-page/finishpro25xp
10/21/20       #2: Brad nailers-Senco 25XP vs Bostitch ...
Tim Glasson
The Bostitch 2 in 1 tool is a home owner grade tool, the pros are not going to like.
Bostitch has a better grade brad gun similar to the senco 25. Senco's tool is a good tool and not sure of your application,but they also have a 21 ga tool that is dinamite, great all around brad tool.
Haffala has access to all senco products.
10/21/20       #3: Brad nailers-Senco 25XP vs Bostitch ...
Jim Member
Hi Tim,
Thanks for your response. I’m primarily going to use the nailer to install window and door casing. When I saw the model with the combo nailer/stapler, I thought I could also use it for my cabinet work to attach backs without having to buy a separate tool.
What is the 18ga Bostitch model that is similar to Senco 25XP? I was thinking of an 18ga vs 21ga to have more holding for the casing.
11/11/20       #4: Brad nailers-Senco 25XP vs Bostitch ...
Nick Drake
If you're planning to do much volume over time, neither. Senco may be getting better in quality again, but even that 25xp is more a "prosumer" quality piece.
Only guns I've never heard complaints about are Omer. Personally I only have a 16 gauge finisher from them, trimmed out a couple homes without one jam or nail set needed and the lockout on the trigger works excellent.
The 12.50 is their 2" 18 gauge model, best pricing is from Allen Staple and Nail corp or Anco fastener sales.
11/15/20       #5: Brad nailers-Senco 25XP vs Bostitch ...
Bill Colligan Member
Senco, as I knew them, when out of business years ago. I found out when I tried to get my SFN-1 and a brad nailer rebuilt. I think they may be owned by Metabo now. For my 18 and 15 gauge I ended up going with Milwaukee 18v. The upside is they work great and no hose to get in the way. The downside is they are larger than air driven and more difficult to maneuver inside tight cabinets,
