Looking for moulding storage options
11/12/20
Lunden Member
Hi guys, I run a warehouse for a cabinet company and I'm running into problems managing my moulding storage. Right now were using vertical racks along the wall. We about about to double the amount of color options we carry and I don't have enough space in the warehouse to extend the current rack. I was thinking a grid/matrix style racking system would be most useful for my situation but am having trouble finding anything online that would be suitable. We planed to build our own rack but it turned out to be fairly costly for something that wouldn't be deconstruct-able in case we had to move. Any feedback to point me in the right direction would be highly appreciated.
Thank you.
11/12/20       #2: Looking for moulding storage option ...
I store a lot of little molding profiles in 6" pvc pipe. How about a rack holding 2' pvc water pipe?
11/13/20       #3: Looking for moulding storage option ...
Lunden Member
Yeah that was my initial suggestion to my boss, I used to store sailing spars/rigging in PVC pipes like that. It would also be pricey and not easily deconstructed and mobile if we ever had to move the warehouse. I was holding on to hope that some warehouse racking system existed that could be purchased, something similar to pallets racks which can easily dissembled and moved. But its looking more and more like we will just have to build something.
11/13/20       #4: Looking for moulding storage option ...
dustin orth
PVC pipe would be my recommendation as well, depending on qty for each bin is how big of pipe I would go with. Maybe do a large grid type shelving unit, then slide the pipes in from the end. No wasted space either as you can put stuff in between pipes as well. One issue this might create is inventory control issues and location control.
11/13/20       #5: Looking for moulding storage option ...
Jack Mazzuchelli  Member
Agree,grid rack, BUILD the rack off the floor high enough for fork lift to get under,wallah ez moveable. Pvc pipe call Charlotte Pipe or other manufacturer direct.Pipe is 20' standard length so racks 20'. ID into wood cubby,card on each cubby for inventory, starting amount, a minus column as molding is pulled,pick a number when reached for notification to replenish
11/13/20       #6: Looking for moulding storage option ...
If you want cheaper, how about cardboard Sonotubes used for pouring concrete columns. I think you can get that up to 3' in diameter.
11/16/20       #7: Looking for moulding storage option ...
Lunden Member
Thanks for all the suggestions, probably going to go with PVC and see if we can make it so a fork lift can gab it.
    • Wood Doctor's Rx, LLC
    • Template Services
    • ECabinet Systems
    • Denray Machine
