Wurth pro 100 full ext slides
11/12/20
Keith
Been using these guides for about a year always fighting tight drawer action Have added spacers thinking drawers are alittle narrow also made them sloppy loose. Can’t seem to figure it out. Are they just cheap? Used hardware resources guides for several years with mixed results also. Any body else fight this? Do I need to move up to better stuff? 30 years ago we used sterling brand and I was in a house lately that I did 22 years ago and was amazed at how smooth they still where. I could actually slam the drawer and they would come back half way out of the hole. I had just forgot how good I once had it
11/12/20       #2: Wurth pro 100 full ext slides ...
duster
The Pro 100 slides are a little stiff if the drawer is not large and loaded. I only use them for big drawers that are going to have some weight in them. They work well for those. I use Pro 80 slides much more for small to medium size drawers that are not heavily loaded because they operate more smoothly.
11/12/20       #3: Wurth pro 100 full ext slides ...
Ryan
It may depend on the market (commercial) you are in and have to use side mount but I would look into the Wurth 500 slides if you do not have to. They run nice and smooth. Most all of our customers want under mount soft close drawers. Under mounts do not come with near the issues of side mount runners.
2/5/21       #5: Wurth pro 100 full ext slides ...
Jeff S Member
I would recommend using Blum 563H.
I really dislike installing drawers with any other guides besides these.
They function flawlessly every time. There is a lot of slop in the back brackets that also makes it forgiving for not so square boxes..
I have used the Wurth ones as well. They just require twice the time of getting them to operate right.
    • J&P Machines
    • CabMaster Software
    • Lignomat
