Sub-Zero Flush Installation (got the wrong unit)
12/10/20
Craig T Member
Hi all, I have a set of cabinets in the shop now which are designed to house a Sub-Zero Built-in unit (BI36/ufd/s). A little backround:
When I pulled up the installation manual from Sub-Zero it gave me an option for "overlay" installation, and "flush inset" installation. I naively went with the flush inset installation as that is what is going to work much better with the space. I come to find out that if you want to do Flush Inset one must purchase an overlay unit and then order stainless panels to install on site.
I'm not installing the cabinets for another month and a half, so normally we just order the correct unit, but with Covid, the correct fridge won't be available for 3 months!
My question is, has anyone ever successfully installed a non-overlay Sub-Zero as flush inset? My opening is 38" wide 84" tall.
Thank you!
12/11/20       #2: Sub-Zero Flush Installation (got th ...
Dan
I don't know if this helps you but if that piece is set with the the trim frame flush to the cabinets' face, it changes the depth profile by about an inch from the standard install and looks pretty clean.
That opening would be about 36 1/8 wide with 1/4" +/- cleats roughly 1/2" back.
    • Steve H. Wall Lumber Co.
    • RT Machine Co.
    • Limtech Industries, Inc.
    • CP Adhesives
    • ECabinet Systems
    • Palmetto Cabinet Doors
    • Anver Corporation
