Upper Cabinet Construction
12/4/20
Huntsvillager Member
I was looking for some thoughts, ideas, guidance, advice, etc. on upper cabinet construction.
Background:
We build upper units with 5 pieces of plywood and a face frame. 3/4" UV1 side top (1), bottom (2), and sides (3,4) and a 1/2" UV1 back (5) for any unit with solid doors on it. There may be partitions of course but we'll just consider the simplest example. The sides and back are dadoed for the top and bottom shelf, and the entire box is pocketholed into the face frame. We flat line finish everything in the shop through a spray machine and assemble after finishing.
Issue:
The problem I am running into is on any prefinished interior upper box, I have to paint the plywood underneath the dado for the bottom shelf. It's not a problem to paint the bottom, but it's a massive waste of time, tape, paper, etc. to tape up the entire side to run it through the machine, and still takes a long time if I have to scuff the 1 1/4" (we normally have a 2" bottom rail on our upper units) of plywood that is exposed on the bottom side of the box.
SO--I was wondering if any of you guys have run into this and come up with something, or how do you deal with this in your shop? I've suggested going to a UV2 side plywood for our bottoms so the bottom of the bottom would be prefinished, but that was a no-go with my boss xD. Any ideas?
12/4/20       #3: Upper Cabinet Construction ...
Eddie
We do our uppers a bit different, we blind dado the bottom and upper pieces to the sides, and we don't run the sides down to the bottom rail frame we keep the sides flush with the bottom, so after the cabinets are installed, we add a 1/4'' skin finish piece.
12/6/20       #4: Upper Cabinet Construction ...
How do you guys like the UV1. We bought some good Columbia stuff 15 years ago and gave up. Way too warped.
We do UV2. The shelves have to be UV2. Any finished ends can be scuffed and top coated no primer required.
We likewise install. Use 1/4” painted ply and shoot it up with 23 gauge pins. A couple of beads of construction adhesive guarantees that the guy ripping them out 50 years from now will say whoa!
12/10/20       #5: Upper Cabinet Construction ...
@Eddie
That sounds interesting but what do you do on your finished ends? Does the side stop shy of the bottom rail there too?
@Adam
We sometimes have issues with the UV1 warping, but not many.. maybe with the last sheet in a bundle -- but we cut our plywood on a CNC that has a vacuum table on it, so as long as the warp is on the "right" side of the board we don't have much problems.
What kind of top coat do you use and how do you find it adheres to the UV? We spray a tinted lacquer and have had problems in the past with the lacquer bonding to the UV.
12/10/20       #6: Upper Cabinet Construction ...
Eddie
Our finished ends comes down the same line as the FF. Our typical cabinet construction have 1 1/2'' FF (unless design calls for something different) stiles with varies sizes top and bottom rail. Our FF is always flush with the inside of the box, so we construct our boxes with blind dado all around, glue and screw our FF to the box and add our finish ends, either slab or framed to the ends. We apply our skin after everything is installed, that way gives us the flexibility with LED lights and power plugs if applied.
12/12/20       #7: Upper Cabinet Construction ...
Guinea Member
Basically same construction method here, except we don't dado shelves into the backs. About a year ago we started shooting painted finishes (mostly M.L. Campbell tinted Magnamax over a lacquer primer) on the UV stuff without scuff sanding. So far no adhesion issues. You would still have to tape and mask, but you may be able to skip the sanding step.
    • J&P Machines
    • CabMaster Software
    • Lignomat
