Shipping cabinets to a dryer climate?
1/23/21
ScottM
I am looking at a project for an existing local customer, new project would be for his house in Tucson Arizona. Cabinets would be manufactured in Western Washington.
My concern is the change in climate. Project includes both stained and painted cabinets.
Is this going to be a problem?
Anyone have experience with similar?
1/23/21       #2: Shipping cabinets to a dryer climat ...
duster
I had a similar project, but with the climate conditions reversed. I built and finished a houseful of cabinets at my shop in the high desert climate of central Idaho and shipped them to a rain forest on hood canal in western Washington. It was a mix of painted and stained cabinets and some millwork. The contractor agreed to take delivery shortly before they were needed and would take care of the installation. I finished my work and sent everything over on time.
However, the the job fell behind schedule, and the cabinets ended up being stored in an unheated garage through a typically damp and rainy winter.
After installation, things began to dry out in the now climate controlled house. The stained and lacquered pieces were fine, but the kitchen, which was a combination of gesso, paint, glazes, and lacquer began crack and flake. The homeowner ended up hiring a finishing crew from Seattle to repair and refinish the damage. I wasn't held responsible, but I felt bad about the situation.
In your case Scott, I would be concerned about shrinkage from solid wood panels (if you're using them) leaving gaps in the finish around frames. Mdf or veneered panels shouldn't be a problem.
View higher quality, full size image (600 X 800)
1/23/21       #3: Shipping cabinets to a dryer climat ...
It will absolutely be an issue, but you tell us nothing about material and style. If you are doing raised panel doors, they will have to be prefinished before assemble because the panels are going to shrink. If you paint the panels in tight after the assembly, all the paint is going to crack around the panels when they shrink. Also consider the temps and time in the truck. If you ship common carrier, they will likely sit in the semi for a couple of days at a terminal waiting for a full load. Better have a shop lined up to fix the trouble and have that included in the bid. Or budget in a trip for your finisher.
2/4/21       #5: Shipping cabinets to a dryer climat ...
Owen  Member
Website: https://www.auspoints.com.au/
Your furniture looks a little classical, consider fashionable furniture?
