Hafele Flap Stay Hamper Kit Cabinet
2/1/21
Matthew Member
Hi,
I was wondering if anyone here has made a cabinet for Hafele's Flap Hamper. The kit I have is item No. 5476.42.994. I have the instructions for the kit installation that uses system holes and I'm good with that but I was wondering if anyone has any recommendations on the inside cabinet width and depth that I have to build for it.
Thank in advance
2/2/21       #2: Hafele Flap Stay Hamper Kit Cabinet ...
Scott Markwood
Website: http://www.hafele.com/us
Hey Matthew, I've installed that kit several times. Your part number has an extra digit though; it's 547.42.994 in black and 547.42.993 in nickel. The width and depth of the cabinet are based more on your choice of hamper than on the fittings, but the Duo fittings need 1" of side clearance. Check out the drawings on the page linked below.
View larger image
Flap Stay Kit, Slanted Laundry Hamper
2/2/21       #3: Hafele Flap Stay Hamper Kit Cabinet ...
Matthew Member
Hi Scott,
That 1” clearance was the measurement I was looking for. Now I’m good.
Thanks for taking the time to respond.
2/2/21       #4: Hafele Flap Stay Hamper Kit Cabinet ...
Scott Markwood
Glad to hear it. Don't miss the step where you reverse the "arms" on one of the Duo fittings so you have damping in both direction.
2/2/21       #5: Hafele Flap Stay Hamper Kit Cabinet ...
Matthew Member
Gotcha. Can’t make any promises but i’ll do best 😆😆👍👍.
2/10/21       #6: Hafele Flap Stay Hamper Kit Cabinet ...
Doug Conti
are the hinges included in this kit? Is there anything else that I need to purchase to install this
2/10/21       #7: Hafele Flap Stay Hamper Kit Cabinet ...
Scott Markwood
Doug, the assumption is that anyone installing this likely has a favorite, trusted hinge, so no hinge is included in the set. Scott
    • Limtech Industries, Inc.
    • Denray Machine
    • Cabinet Pro
    • Impact Search and Placement
    • RT Machine Co.
