Industrial Machine Profile Sanders
2/5/21
Mike D  Member
We are looking for a feed through brush sander capable of sanding profiled doors. Capable of fine sanding on primer coats as well.
Took a look at the Houfek Final but was not impressed with it. Seemed like still had to do too much before and after on the doors. Is anyone using something similar that is worth the nearly 100k cost on them?
2/6/21       #2: Industrial Machine Profile Sanders ...
I am no expert. I think the purpose of a brush sander is to break the corners. It is not designed to sand the profiles.
What are you trying to achieve?
2/8/21       #3: Industrial Machine Profile Sanders ...
Mike D  Member
The 'new generation' of sanders will do crown moldings and door profiles. Hitting pretty much everything or so they claim.
Limited to surfaces and not door edges of course.
We're looking for a machine to do 75% percent of it.
Just can't hire anyone for the sanding position so need machines to take up the slack.
