Curved work
2/8/21
Joel D'Angelo
Hello all,
Over the years I have done one small built in that had a curve. I pretty much hacked my way through that using italian ply and azek. I am very confident in my cabinet/furniture making skills besides. Can any of you recommend any reading on the subject? Thanks
2/9/21       #2: Curved work ...
Years ago I worked for a company that did tons of curved reception counters. We used to lay plywood on the floor and lay out the radius’s, some of them were vey large. All the curved walls in the counters were built like a stud wall, we would used curved plates and 3/4 inch plywood cut and framed like studs. We clad the walls with 3/4 inch plywood that
had saw cuts every 1/2 inch on center or less depending on the radius. We glued mostly plastic laminate or veneer to this ply’d. You can also use rubber ply like you did.
The plywood worked great as studs, we could drill holes in every stud so that all the electrical, data cable and phone lines could be run. There was usually some removable access panels on the inside under the desk top.
Sorry I don’t have any readings or books that I can recommend
2/9/21       #3: Curved work ...
Joel D'Angelo
What I had in mind specifically was a bow front cabinet. This would involve a curved FF, Drawers, and possibly doors, Also curved trims. I would like to challenge myself and I could also up my game for potential customers.
2/9/21       #4: Curved work ...
PKD
Website: http://www.premierekitchensllc.com
Joel u can find that info right here on wood web.
Go to knowledge base general items>
search/browse knowledge base>
wood working misc>
bending wood>
there is an article there. Radius cabinet job project review. Posted in 2013
2/9/21       #5: Curved work ...
Joel,
We did some of that as well, but generally we tried to build the cabinets in sections and keep the fronts flat as the time and work involved is way less.
What kind of material were you planning on using? There may be simpler ways to do it now days or specialized equipment. When we did it we used vacuum bags and a mould. Cut your material in strips and glue it back up in the vacuum bag against the curved mould.
You could probably figure out a clamping system as well. I know the railings company has special made steel L brackets that they fasten to the floor to glue up their curved railings.
Good luck
