Light weight MDF
3/23/21
I am looking for input on the light weight MDF, I need to build some paint grade 5 piece cabinet doors and I am going to be using 1/2 inch MDF for the panels. I would like to know how the light weight version works as far as applying finishes? I would imagine it machines similar to regular MDF, but was wondering if the faces were more porous or much the same?
I am wondering what brands you like or recommend? Thanks for any input.
3/23/21       #2: Light weight MDF ...
I only use double refined MDF for door panels when painting. Regular MDF needs 2 coats of primer on the flat faces and sometimes more on the milled surfaces. I'm sure the lightweight needs just as many if not more because it's going to have more spaces between the fibers to make it light weight.
3/25/21       #3: Light weight MDF ...
Adam Spees
Leo hit the nail
