KV Standard Cutter
5/25/17
Paul A Member
One of my past companies I worked at, we had a guillotine type cutter for cutting the KV 255 standards. I have a project now that calls for these, haven't used the KV 255's in a long time. Anyone know where I can find this cutter, if there still make it?
5/29/17       #2: KV Standard Cutter ...
JimHerron
I had one a millenia ago.
That said, I recently bought a metal cutting chopsaw (carbide blade, so no burn) that would allow you to cut multiple ganged pieces, with a finished cut in one lick.
The 255 guillotine only cuts one at a time, so if any quantity, your looking at a lot of fiddling.
I bought it to cut oval closet rod. Does a great job with no burrs at all.
Also inexpensive at about 100.00
4/19/21       #3: KV Standard Cutter ...
Bruce Member
I have one that I am selling. It works great. Clamp or bolt it to a work table. It's fast, cuts clean, and there are no flying metal shavings. $60 + $25 UPS shipping to continental US. Venmo or Zelle payment. Local pick up OK too. MN 55436.
7/25/22       #5: KV Standard Cutter ...
David Gunter
Is the K.V. cutter still available
Thanks David 559-362-4450
7/26/22       #6: KV Standard Cutter ...
Bruce
This cutter was sold a long time ago. I cannot get logged in to remove the post.
    • J&P Machines
    • CabMaster Software
    • Lignomat
