Shaper replacement
4/29/21
I have a couple of shapers, one of them is fairly old and I was thinking of replacing it with a newer used shaper. The ones I have now are 6.5 and 7.5 hp I believe. I was looking at a SCM shaper and it was 9 hp. Some other features that I have never used and never owned are a sliding table or a tilting spindle.
I am looking for some feed back from others here, do you use a tilting spindle often, do you use your sliding table much? How much HP is enough?
I generally just use mine for building doors and running some mouldings/profiles from time to time. Maybe I am under utilizing them and the options that are available?
Thanks for any input.
4/30/21       #2: Shaper replacement ...
Jared Member
I currently have 6hp, 7.5hp and 9hp shapers. 2 with sliders and one with tilting spindle. I could easily live without the sliders. I run a sled for cabinet door coping so the sliding table is more of a hindrance for clamping a outboard fence than a useful addition there. Tilt is nice to have. Its not necessary but it adds capabilities and the ability to get more from a existing profile (really talking moulding, millwork or furniture there)
Hp.. Ive never heard anyone complained about having too much.
5/1/21       #3: Shaper replacement ...
Mark
If your doing a lot of C&P work for doors and paneling a slider is definitely a plus, provided its tight with no slop, sometimes hard to find on used machines.
A tilt spindle is useful if you do any curve molding work and it does extend the range of profile for cutters, but truthfully, I break mine from 90 degrees maybe 10 percent of the time. For bevels and such. i most often use an adjustable angle head, mine is a Leitz
IMO, a good addition would be the slider
