some sort of flexible sander???
8/25/21
the google
everybody,
i'm making some wooden tractor seats for myself. these are curved/carved and sanding them with our regular orbitals is not a good time. we use 6" orbits so that makes it even more difficult.
is there some sort of flexible sander out there that would work for curved work? i've seen 3" pad obrits and they may work, but i'd prefer something flexible. a bladder sander on a grinder might do the trick. i've just never used one of those machines before, and only seen them for edge work. our piece is 16" x 13" flat.
8/25/21       #2: some sort of flexible sander??? ...
Karla Gossling
You should be able to find a soft pad that is thicker and obviously softer. Fairly standard item.
8/25/21       #3: some sort of flexible sander??? ...
Keith Newton
I would start with one of the chainsaw tooth disk on a right angle grinder, followed by the coarsest grit sanding disk on the same tool before going to the pad or orbital sander.
https://www.tootock.com/products/tootock-carving-grinder-wood-carving-chain-disc-wc190?variant=40371034325173&currency=USD&utm_medium=product_sync&utm_source=google&utm_content=sag_organic&utm_campaign=sag_organic&gclid=CjwKCAjw1JeJBhB9EiwAV612y_q-nY2rGfB1TspMgVlUWZdp5sSJOOCg-tSE1fgiHqbJE34Q9SV7ABoCctEQAvD_BwE
8/25/21       #4: some sort of flexible sander??? ...
duster
I've done lots of carved chair seats using a 7" grinder with a 50 grit disc to start and a 100 grit disc to clean up.
Finish with a 150 grit random orbital sander. We use a 5" sander for that. The whole process takes about 20 minutes per seat.
View higher quality, full size image (576 X 456)
8/26/21       #5: some sort of flexible sander??? ...
Like Karla mentioned, you need a sander with a thick flexible pad, the best one on the market is probably the Surf Prep , however they are not cheap like most off the shelf sanders.
Surfprepsanding.com
8/26/21       #6: some sort of flexible sander??? ...
rich c
Look at 3:59 in this video
https://www.youtube.com/watch?v=K30E6GpO7h8
8/26/21       #7: some sort of flexible sander??? ...
the google
thanks everyone. i forgot about the surfprep. we have the 4" rectangular sander with soft pads. obviously, we don't use it much otherwise i would have already thought about this.
rich - really cool. just not worth making a custom sander for a few seats.
    • GreCon
    • WalzCraft
    • WOODWEB, Inc.
    • American Vision Cabinets
    • J&P Machines
    • O'Shea Lumber Company
      Merchants of Fine Woods
