Tall Bookcase Assembly Options
1/17/22
Ron M Member
I'm a one-man shop specializing mainly in custom furniture. I have occasional part-time help for installs and deliveries. I've been commissioned to complete 11' of wall-to-wall ff bookcases approx. 101" tall. The room is 10' tall.
Using the Sagulator as reference, I plan to divide these into (4) 8' tall sections and set on a 5" ladder base. Each section will have .75" Maple ply top/bottom plus 5 fixed shelves let in with a full .25" deep dado. A 1.25" nosing will be applied between stiles. The rear of the shelves will be further supported by driving screws through the .25" or .5" backs. Finish will be applied before assembly.
I thought about assembling 7pcs per section in those tight dadoes not to mention bulky delivery and install. Is it easier to to build (2 or 4) lower and (2 or 4) upper sections to ease assembly and handling? I can use .5" ply where the cases meet to keep my nosing consistent.
Thank you in advance and for such a fantastic forum.
1/17/22       #2: Tall Bookcase Assembly Options ...
Mark B
Splitting them up vertically would seem to depend on the design/layout as you'll be left with a fixed shelf? One would think these would be single units at 101" tall. Fully shop finished (for me) alot would depend on the layout and details like how you deal with the pre-finshed face frames when you put them together unless they are going to be clipped together like kitchen cabs.
A 101" tall carcass (back, sides, deck and lid) wouldnt be horribly hard to handle alone with a couple dollies as long as no stairs.
1/17/22       #3: Tall Bookcase Assembly Options ...
Bruce H
I'd split horizontally, two sections wide (4 total) . Or, assemble the entire cabinet in place. No point i making it difficult.
1/17/22       #4: Tall Bookcase Assembly Options ...
In a wall to wall situation, I would assemble the entire thing on site. You get to finish all the pieces in the flat and then on site just shoot screws through the sides into the shelves with no glue. If you really want glue, mask off the dadoes and a shallow bit on the ends of the shelves. I'd use knock down fasteners for the face frame, or pin nail and touch-up on site. You didn't mention if stain or paint grade.
1/17/22       #5: Tall Bookcase Assembly Options ...
Ron M Member
Rich C, your contributions are always appreciated. I like the idea of assembly on-site. This of course will be partially necessary for the face frames. Assembling these without glue in the dadoes is entirely feasible in the shop (after prefinishing). I simply wasn't sure if the glue actually added anything. These are Maple bookcases with a Natural finish. There isn't a break front nor are there pilasters incorporated into the design.
1/18/22       #6: Tall Bookcase Assembly Options ...
Peter Matos
I typically do bookshelves as single vertical sections sitting atop a ladder frame toe kick and sharing stiles to join adjacent units together in the field. Installation with biscuits and glue or hidden screws depending on design of shelving. Simple and easy.
    • J&P Machines
    • CabMaster Software
    • Lignomat
