Install
1/30/22
Matt Canham Member
What tricks do you guys use when installing large cabinets as a one man shop. Not as young as I used to be.
TIA
1/30/22       #2: Install ...
I call my brother.
1/31/22       #3: Install ...
james e mcgrew  Member
Wall french cleats
1/31/22       #4: Install ...
Peter Member
We have a two man install team, and standard practice is if I send out a particularly large cabinet (extremely heavy, or won't make tight turns in the house, etc.) I'll send it out to be assembled on site. We'll do the finish work and assemble it once in the shop to make sure everything is right, then disassemble it and send it to the job. Takes a little longer, but it saves you the hassle of trying to move them around by yourself as you can build it in place. Another thing we utilize are pole jacks for larger uppers. You can pretty much get it where you want it and jack the cabinet up so you can get it screwed off to the wall without trying to support it at the same time. This takes a little getting used to, but with a 2x4 cleat up 54" it usually doesn't present any problem.
Of course, the french cleat option works great too, as long as you have some scribe mold to cover the gaps on your finished ends.
2/11/22       #5: Install ...
Jonathon Member
We use a cabinet jack that has more than paid for itself and some times a cleat and the third hand from fast cap.
