Aventos HK Top lift mechanism
2/1/22
Adam B Member
Anyone use the Aventos HK Top lift mechanism in an inset application? I don't see why it wouldn't work, but since it was designed for face frame / frameless applications there isn't much info regarding clearances for an inset application. Please let me know if you have any information that would help, thank you in advance.
2/1/22       #2: Aventos HK Top lift mechanism ...
Chris
Yes. If the face frame stile isn’t flush with your gable you need a spacer block behind the Aventos
Mechanism to bring it in plane with the inside edge of the face frame.. hopefully that made sense.
2/2/22       #3: Aventos HK Top lift mechanism ...
Adam B Member
Thank you for chiming in Chris. I have included a pic of where this flip up panel is going. As you can see there is a jamb that will serve as the the connection point for the lift up panel. I am currently planning for the panel to be inset & flush with the front of the jamb. I am planning for an 1/8" reveal at both the top & bottom of the panel. I just want to make sure that I have enough clearance for the panel to flip up and not "bind" when lifted. Thoughts?
View higher quality, full size image (2016 X 1134)
2/2/22       #4: Aventos HK Top lift mechanism ...
Tom Gafgen
It will clear . Ive done them with similar situations.
2/2/22       #5: Aventos HK Top lift mechanism ...
Adam B Member
Thank you Tom for the info!
