Narrow "Shaker" glass door
2/3/22
chris
Hopefully the quotation marks around "shaker" will keep everyone calm regarding the proper use of the term.
We are getting a lot of requests for shaker doors with 1" rails and stiles. We've figured out a few ways to do this for typical doors and drawerfronts. Basically a 2" rail/stile with the front relieved back to 1" ( think of the cross section as a "J shape".
This however does not work for a glass door as you'd se through the glass into the solid behind. Does anyone have a suggestion as to how to build these, and what a hinging solution would be?
2/3/22       #3: Narrow "Shaker" glass doo ...
Matt Calnen
I would tell you, but you offended me with your use of the term Shaker, so I will leave wooden forever and tell all my friends to do the same! 😂
2/3/22       #4: Narrow "Shaker" glass doo ...
Roy Cameron
I piece mdf frame with Salice Air hinge.
2/5/22       #5: Narrow "Shaker" glass doo ...
Nate Cougill  Member
Website: http://www.cougilldiversified.com
Make them in 1” stock and finger-joint them. B**m makes a narrow door adapter plate for aventos.
