Edgebander Selection & Features
2/23/22
Rich Member
Website: http://perfectocorp.com
If you had a budget of 30K-50k to purchase a new edgebander, what features would you need this equipment to have and what Brand what you steer towards?
Mostly used for high end production of Frameless Cabinets and Custom Closets. I understand The budget may be an overkill for my needs, but I like like to know the bells and whistles options.
Pre Milling
Corner Corner
Corner Buffing
Top and Bottom
Radius Scrapers
Buffing
Spray Station
to name a few.
Thanks!
3/5/22       #2: Edgebander Selection & Features ...
Derrek
Website: http://www.closetdr.com
I’ve had several banders over the years and currently have a brand new Vantedge
It depends on what you want to do.
For me premill is a must. We take off .5 mm on everything it just gives you a better edge to start with. We only run 1mm and have machine setup with 2mm radius tooling for a nice rounded edge. We do a fair amount of doors so corner rounding is a must. We have glue scraper with the cleaning agent sprayers as well.
$30k isn’t going to get you much more than top and bottom and end trim. 50 might get you premill.
Personally, I would never buy a used bander, there is just to many moving parts to get them dialed in perfect and it’s being sold for a reason
3/5/22       #3: Edgebander Selection & Features ...
Rich Member
Derek,
Thanks for the response. Since my original post, I've done more research and realized the budget must be raised to the 60-65K range, And you are correct, its a piece of equipment that you do not want to purchase used, not that I ever had any intentions to.
I seen a demonstration of a Bisse Jade 240 which I was definitely impressed.
I never heard of Vantedge, but I will look into it. How do you like it?
3/5/22       #4: Edgebander Selection & Features ...
Derrek
Website: http://closetDr.com
So far we have been very happy. It’s been up and running for only 2 weeks. Very simple to operate, solid well built machine and excellent finish. Several little things that I really like about it. Below is link to video I made at show when I bought it
Pm me if you want to talk more
https://youtu.be/BQyyKvlsnbw
10/16/22       #5: Edgebander Selection & Features ...
Sean Kovacs  Member
Pre mill is now a standard want/need on an edgebander. In fact any used ones Ive ever came across without one get ignored. I import edgebanders from Turkey from a company called AyzaMizrak. Im an old Holz Her and Homag guy and have had my hands into every big name bander you can name. Im anuts and bolts serivce tech at heart so when I went to the factory this past May, I was really impressed. Far better quality then whats coming out of China and not as expensive as the Italians "und ze Germans" ;-) have a look, Im importing for Canada and US.
