Saw blade for trimming hardwood cabinet doors.
3/2/22
Can anyone recommend a good saw blade for trimming and squaring 5 piece hardwood cabinet doors?
All the blades I use on my sliding Scm saw are FS Tool, I have blades for sheet goods, I have blades for cross cuts and I have blades for ripping.
I am looking for one blade that will do a good job for ripping and crosscutting and leave minimal chipping and saw marks that I will have to sand out.
My supplier is a salesman if you get my drift, he does a good job sharpening, but he hasn’t cut a piece of wood in his life.
3/2/22       #2: Saw blade for trimming hardwood cab ...
Roy Cameron
80 tooth fine trim blade is what I use. Decent at ripping and crosscutting.
3/2/22       #3: Saw blade for trimming hardwood cab ...
Mark B
Are you pretty solid in your saw setup? I find with a wide variety of blades we can get pretty much glue line rips (a sanded finish for the most part) across the board off the slider but I spend a tremendous amount of time on setup and alignment (mostly by ear) on the wagon side of the saw (rarely use the fence).
I hate to say it but a vast majority of time there is a 10" heavy plate rip blade in the saw and I run it on almost everything without issue.
No idea on your end but you may get much better results after spending a half a day re-dialing the saw?
3/2/22       #4: Saw blade for trimming hardwood cab ...
Daniel
check out leitz saw blades they are said to be one of the best in the industry. in blades and in sharpening pretty much anything. we have a dealer here in MN but i think the company is in michigan.
3/3/22       #5: Saw blade for trimming hardwood cab ...
I use FS Tools 4 and a raker combination blade for this type of work. It will rip cleanly and if I back up the cross cut it is tear out free.
3/6/22       #6: Saw blade for trimming hardwood cab ...
Nate Cougill  Member
Website: http://www.cougilldiversified.com
I’ve been getting good results with a sanding disc in place of a blade and running them through. If there’s a lot of them, set up a feeder and it’s very efficient.
3/8/22       #7: Saw blade for trimming hardwood cab ...
cabinetmaker
we trim with a triple tooth that's in the slider if trimming needed
I find myself lecturing of cutting square parts, machining square and assembling square to alleviate all the damned trimming
3/8/22       #8: Saw blade for trimming hardwood cab ...
Adam Spees
Forrest WW2 40 tooth. FS makes a similar blade.
Constant changes between crosscutting and ripping is where those blades excel. The geometry is completely different from other grinds. The sides of the blades scrape the wood when ripping the steepish alternate bevel crosscuts really well.
50 tooth combi blades do nothing well.
