SUB- ZERO BI-48SD/O INSTALLATION
3/21/22
Am i the only one that seems to have problem's with applied panel fitment ? so are the instructions wrong? or am i just missing somthing? this particular application is a flush install , Made the the panel to the specifcation included in the desighn guide, Backer panel is wrong size. are the instuctions wrong?? any help would be greatly appreciated.
3/21/22 #2: SUB- ZERO BI-48SD/O INSTALLATION ...
this was off the sub zero website
View higher quality, full size image (739 X 895)
3/21/22 #3: SUB- ZERO BI-48SD/O INSTALLATION ...
Did you use the page showing you how the spacer and back panel are applied top, bottom, left and right? Many make the mistake of applying these with equal reveals to your finished panel but they are different for each
3/21/22 #4: SUB- ZERO BI-48SD/O INSTALLATION ...
I just did one of these. The frig was already at their house, so I checked the dimensions in the instructions against the actual doors, and found them to be accurate. The panels fit perfectly. If you don't have the frig, it might be a bit of a crapshoot, but I've found Subzero to be more accurate than most. It was tricky laying out the backer parts the way they described.
