Intro to Line Boring Operations
5/6/22
Brent Member
Website: http://www.parkhillwoodcraft.ca
In the past I've always used various drilling jigs to machine my shelf pin holes. I recently invested in a Ritter 13-spindle line boring machine, and used it today for the first time. My most common operations are drilling upper and lower gables. Is there a trick to setting up the LH and RH fence stops to get my holes to line up when registering the top/bottom off the two stops? I seemed to fiddle a lot to get the holes to line up side to send and front to back between the two gables of a cabinet (I still had fluctuations of 1/16" between front and back rows and fear wobbly shelves).
Any tips on the process of operations would be helpful. Thanks.
5/7/22       #3: Intro to Line Boring Operations ...
Jim
A good way is the use of a long back fence with multiple swing away stops set both ways from center
I use 46.5 from bottom to center of first hole, them set the remaining stops to hit multiples of 32mm to extend the line bore pattern
The pointed stops that center in the hole can allow slop to creep in
Gannomat makes use of a reliable and accurate back fence system
5/8/22       #4: Intro to Line Boring Operations ...
Brent Member
Thanks Jim. I'll look into the multiple stops for my fence. I found out pretty quick using the indexing pins was inaccurate, even after only one instance - what a joke. So basically, I need to have my LH and RH stops set EXACTLY the same distance from the center drill bit on both sides to ensure any type of accuracy correct? I assume this because the holes on the front edge of the gable reference off a different stop than the back edge holes because the part has to be flipped front-to-back. I see now why 21/23-spindle machines are great because I can drill an entire upper 36-42" gable in one go!
