What flavor edgebanding glue are you using?
6/30/22
Pdub Member
I posted this in the CNC forum and got crickets. So I'm reposting here. Hope that's kosher with the admin.
We just picked up a new bander. Went from the puck system to a gluepot.
We always stuck with what we knew worked in our tired old machine - Dorus HKP25. Now that I have a lot more glue options, I'm wondering what everyone is liking these days?
I've ONLY use EVA in the past. I'm not interested in PUR, but what about PO?
We also always used "natural" color for everything. I'm curious about clear though? We don't plan on changing colors much if we don't need to.
What brands do you like? Dorus was good to us. Sounds like Jowat is good? What about Klieberit?
We are typically about 90% 1 mil. wood, but going to start pushing more PVC.
6/30/22       #2: What flavor edgebanding glue are yo ...
Jonathan Mahnken
We are using the Jowat in natural. The machine company I bought from says clear glue is best for the machine because you get less burning in the glue pot, but my glue supplier recomended that the natural color is a little more versatile
7/1/22       #3: What flavor edgebanding glue are yo ...
Roy Cameron
Jowat natural unfilled in a me20 bander
7/1/22       #4: What flavor edgebanding glue are yo ...
Daniel Member
Jowat clear for everything. Do mostly PVC
7/2/22       #5: What flavor edgebanding glue are yo ...
Rob Young  Member
More information on your machine and materials run are helpful in determining the best options for glue. Glues are rated for temperature ranges at various feed speeds. What might be appropriate for a 20 meter a minute feed on one edgebander may not work well on an edgebander with a feed speed of 8 meters a minute. Clear glue will be best for darker colors but may leave a distinct looking line on whites.
As a general rule with EVA, I recommend a natural unfilled glue like Jowat 280.3. If you find you are having issues with glue stringing, you might switch to a formula designed to eliminate stringing.
As an independent technician I used to work on every machinery brand but now that Nutek Machinery is importing high quality, production efficient European machinery we are only servicing those brands we import. The Ott edgebander line has the only top driven glue pot in the industry with a dry box to preserve used PUR glue for up to seven days. There are no seals in the bottom of the glue pot to leak and I’m amazed with the invisible glue joints and superior bond. With the Ott system I would recommend nothing but PUR.
