widebelt platen use
7/13/22
KEVIN JENNESS
On another forum a user said that he uses the platen on intermediate grit (120#) passes because otherwise he cannot get rid of the 120# scratch pattern and chatter marks from belt splices with the final pass. This is contrary to my understanding of common practice, using the platen on only the final pass. Am I all wet? Don't multi-head sanders typically have a platen only on the final station?
7/13/22       #2: widebelt platen use ...
Al
I use platen on mine at 120 grit also. It’s single 37” wide belt basic machine. There is about 1/2 dozen holes where you increase platen depth. I only ever go to 2nd hole. If the belt is new then I would go to 150 belt and do same process but as 120 belt wears a little I use that belt. I then go to orbital and start at 100, 120 and then 150. When I use platen like the other fellow you mentioned it makes for quick work on the orbital.
7/13/22       #3: widebelt platen use ...
I only use the platen on the last head, and final pass.
I do 80/120, and 150/180
9/6/22       #4: widebelt platen use ...
M Member
Platen on 150 up. The belt joint you want on a cloth is a tee joint top skived and have them use the yellow kevlar tape, it is only 1 thou thick
For paper butt joint with the yellow tape, I don’t think they typically will top skive a paper belt but i think my most recent order from Klingspor they did. This eliminated all of my chatter due to the fact that I have a steel head.
    • J&P Machines
    • CabMaster Software
    • Lignomat
