Panel Genie
Push to open with soft close hinges
8/1/22
I see this has been asked a few times
It seems that they are not compatible
However Dennis implied that Salice does make something that is compatible
Is this a yes or a no or a maybe?
8/2/22       #2: Push to open with soft close hinges ...
JK Interior Finish Inc.
Blum long throw tip on cylinders will work fine with soft close hinges, they do not use a magnet just have a soft plastic end.
8/2/22       #3: Push to open with soft close hinges ...
8/3/22       #4: Push to open with soft close hinges ...
Technically nothing will really do the job. You can have the slow close but you will still need to push the door all the way closed to overcome the push to open mechanism.
And yes the long throw Blum pushes the soft close open far enough to operate nicely.
8/3/22       #5: Push to open with soft close hinges ...
Thanks Leo
8/4/22       #6: Push to open with soft close hinges ...
If the customer wants push to open it sounds like they would be better off with free swinging hinges?
8/4/22       #7: Push to open with soft close hinges ...
Pdub Member
Correct. But then they will complain that they don't have soft close....
8/4/22       #8: Push to open with soft close hinges ...
To them the push to open was a priority
8/4/22       #9: Push to open with soft close hinges ...
BTW do the Blum 956A1006 work with free swinging hinges?
8/4/22       #10: Push to open with soft close hinges ...
Use one soft close and one self close hinge so it'll still be soft close but it'll be quicker.
    Lamello
