Airtrec Edging Issue
8/19/22
Joe Member
We have an issue with an ‘Airtec’ Edgebander and looking for some advice. It seems to intermittently leave some gaps. These are all on the top edge and mainly towards the back corner. I don’t think it’s a temperature issues and have tried all sorts of settings. Pictures show that rest of the board is fine - just issues on trailing edge.
Appreciate any help.
View higher quality, full size image (3840 X 2160)
8/20/22       #2: Airtrec Edging Issue ...
Rich  Member
If I had to guess I would check the pressure section settings. I could be much pressure (or set to close) and flexing the band off the board as it exits.
8/20/22       #3: Airtrec Edging Issue ...
My first thought would be misalignment of the pressure roller or perhaps not getting that edge fully heated on the way through. Not familiar with the Airtec but where your not applying any glue it would seem to either be a lack of heat or a lack of pressure. If the glue is hot when its applied and pressure is correct even with hot air tape I'd be surprised if it released after the roller. I'd be checking off heat and panel-to-roller alignment first.
