Carcase for frameless tall cab with double-oven opening
9/17/22
Gene Davis
I have to do one of these for the first time, and see this at Baker Cabinets website.
Double-thickness deck under and double-thickness fixed shelf over. I'm using "deck" and "fixed shelf" terms because it's what the eCabinets app calls them.
Looks straightforward. Top, mid, and bottom stretcher/nailers across back. Use 1-1/4 screws and put about 9 in a 3x3 field to screw the deck and shelf so they act more like thick members.
Seems also in line with the installation specs of most of the maker's products: GE, Thermador, and others are showing a 1.5" border around the opening, even for frameless. The products all have wide face flanges.
Is this what you do for frameless builds needing these double oven appliance openings?
View higher quality, full size image (922 X 708)
View higher quality, full size image (1344 X 795)
9/18/22       #2: Carcase for frameless tall cab with ...
Jim Herron
Some manufacturers have recently started, but it would be much easier laying things out if they would include the required OVERLAPS for the appliances, not just the rough opening and overall height and width
Frameless looks best with reveals around the appliance in keeping with the rest of the project
Some appliances are flush on bottom while some have the required support 1 1/2" or more above the lower edge of the appliance, same with the top overlap
11/17/22       #3: Carcase for frameless tall cab with ...
Rodney Member
Not sure about ecab software we use cabinet vision we sometime use an appliance frame on a framless cabinet.
    • J&P Machines
    • CabMaster Software
    • Lignomat
