need a ribbed spline similar to a Lamello K20
10/3/22
Matt
Is anyone familiar with a source for a ribbed spline that fits a standard biscuit cutter slot kerf thickness (approx 4mm)? Something similar to a Lamello K-20, but in spline form? Need this to have it's own physical bite into the material like the Lamello, this will be used on a lot of materials such as RTF and high gloss acrylic where there's edgeband that won't allow for a glue joint, other than the meager amount we'd be fitting in the dado.
This will be used to join a two pieces of material together that are 3" wide, 8ft long, on a 90 degree angle basically like a flat top-mount crown and also as a light rail under the cabinets. So, the joint needs to be structurally sound but isn't going to be load bearing.
10/5/22       #2: need a ribbed spline similar to a L ...
Chris Hofmann
Website: https://www.csaw.com/lamello/
Hi Matt,
If you strike out trying to find what you're looking for, you could always just make a 4mm running slot with your Lamello biscuit joiner and then put in as many K-20s as you'd like/need. The best video I could find to illustrate this starts around the 0:12 mark in the Divario P-System instructional video, using the Zeta P2 machine, in the link below - but the concept is the same.
Hope that helps,
Chris
https://www.lamello.com/product/p-system-verbinder/divario-p-18/
