Brandt Edgebander
10/13/22
Jim Member
Can anyone recommend a service technician in the Atlanta area?
10/16/22       #3: Brandt Edgebander ...
Sean Kovacs  Member
I was there for IWF, had i had my tools with me, I could have swung by... whats the issue?
10/16/22       #4: Brandt Edgebander ...
Jim Member
Thanks for the response! I was suppose to be there as well but ended up in the hospital the day before :-(
The front end trimmer is not working and glue is clumpy. Just bought this machine and I'm trying to get it working properly.
Thanks for you response!
10/22/22       #5: Brandt Edgebander ...
Scott Owen
Jim,
What model and year of machine do you have?
10/22/22       #6: Brandt Edgebander ...
Jim Member
It's a 2002 KD55
10/24/22       #7: Brandt Edgebander ...
Jim,
You figure out the edgebander? Do you have the manual and wiring diagram for the machine.
The trimmer should be fairly straight forward to diagnose, can you switch the wires with the other trimmer or get a multimeter and make sure you have power at the motor?
The lumpy glue seems like it is not getting hot enough, I would get a point and shoot thermometer and take a shot at the glue when it is fully heated. I believe the temperature on those older brandt edgebanders should be around 200 degrees. The other thing is the kind of glue. Make sure you have glue pellets meant for that machine.
10/24/22       #8: Brandt Edgebander ...
Jim Member
Hey Scott,
Thanks for reaching out! I will try switching the end trimmers and check glue temp. Have a great day!
Cheers, Jim
    • J&P Machines
    • CabMaster Software
    • Lignomat
