Ironwood / Cantek Wide Belt Sander
5/17/22
Ben Zacharias Member
Website: http://www.vangarde.com
We are looking into purchasing a new 2 head 43" wide belt sander. Does anyone have any experience using the Ironwood 124RK machine? Any recommendations for another brand or model? Wurth is recommending the Cantek brand, but we do not have any experience with them either.
We will be using it primarily to sand and prep hardwood doors and face frames.
10/16/22       #2: Ironwood / Cantek Wide Belt Sander ...
Sean Kovacs  Member
There are a couple of schools of thought on that. I know the Cantek brand very well and Ironwood is more or less a Cantek with another paint job, so either or will achieve the same thing. You need to ask yourself what you'll be sanding because these types of sanders are usually "limited" in scope because (unless they've caught up) don't have alot of flexibility in the platen heads like the sanders in the next price point. The other thing you need to ask yourself is how long do you intend on being in business.. Its a question worth asking seriously because the Canteks and Ironwoods wont last or will be very tired after 10 years of use. Its almost worth considering upping your budget on a two headed segmented pad general purpose sander from Germany or Italy and itll give you a greater degree of control by allowing you to create plug and play programs that any operator can call up, the set up and operation being automatic will reduce operator error and intervention, thus minimizing re work and slowed production (choke points) at the sander.
    • Texas Woodworking Festival
    • J&P Machines
    • Forestry.com
    • Better Vacuum Cups, Inc.
    • Laguna Tools
