capinet vision report
10/16/22
cadcam Member
How do I get a report like this format?
Through the program cabinet vision
View higher quality, full size image (1680 X 1050)
10/17/22       #2: capinet vision report ...
Jared
Buy the core program and xOptimizer.
10/17/22       #4: capinet vision report ...
cadam Member
i have do xoptimizer But it doesn't have the format I want .
10/17/22       #5: capinet vision report ...
Jared
I looked at your pic closer and understand what you're asking now. You want the information in the table below the nest to appear on the part, instead of a sheet part number on the part that refers to the table for the rest of the info. As of now, there is a way to get the dimensions or cabinet numbers to show up on the part. CV's answer to your question will be to buy the Label-It add-on, because printed labels will have cabinet number, dimensions and banding indicators. Maybe it's called xLabel now. I don't know, as I don't own it.
I did take the time to edit the nest report and reorder the columns to make lookups easier. Putting sheet part number next to cabinet number helps. I put any unusual banding info in a part's comment field so it shows up on the nest report. I cut on CNC so it's usually clear what edges get banding, but I'm guessing you're cutting on a saw.
10/17/22       #6: capinet vision report ...
cadam Member
Thank you very much for your time
Mr. Jared
I will try this way
10/23/22       #7: capinet vision report ...
cadam Member
View higher quality, full size image (1051 X 532)
10/23/22       #8: capinet vision report ...
cadam Member
How view label on Sheet?
    • J&P Machines
    • CabMaster Software
    • Lignomat
