Biesse PolyMac ERGHO-3
10/14/22
Tip
Does any one know about the electronics and controls on this old bander? Does it have a very complex computer controller? Or is it pretty much a simplistic design with not complex controls? Getting ready to fire it up. It’s been sitting for about 3 years. Hoping the electronics are still good. Would I have any options to get it working if the electronics aren’t working right? I am speaking specifically about the control system. What is used to operate the machine.
10/16/22       #2: Biesse PolyMac ERGHO-3 ...
Sean Kovacs  Member
as long as the eeprom battery didnt die and wipe out all the line point control parameters you should be okay, Id be more concerned with the condition of the glue pot and surface rust on the moving parts.
10/29/22       #3: Biesse PolyMac ERGHO-3 ...
Tip Member
Sean Kovacs I think I got it to turn on and power up. The glue pot is rough and there is a small amount of rust on some of the post and such inside. Haven’t tried running any parts or even getting it dialed in. What would be your advice on how to restore the glue pot and get the surface rust off the post and adjustment areas?
    • Country Saw and Knife
    • GreCon
    • WalzCraft
    • Denray Machine
    • ECabinet Systems
    • Original Saw Company
      Industrial Radial Arm Saws
