Edge sanding on wide belt?
5/13/22
Mr Fee Member
Is it possible to edge sand on a wide belt? We have an older kundig 53" single drum with air platten. We still hand sand all filler edges. I was wondering why we don't stack several on edge and send them through. Does anyone do this and is there a downside.
5/13/22       #2: Edge sanding on wide belt? ...
gary
We do it all the time with our widebelt and planer/sander. Just make sure you run them straight with the feed belt and don't angle them or they will tip.
5/20/22       #3: Edge sanding on wide belt? ...
Nick Cook Member
Website: http://kootenaicabinets.com
I take all the parts, provided you have several and clamp them together on both ends in such a way as to NOT hit the table or the belt. Thus you have a wide surface.
5/20/22       #4: Edge sanding on wide belt? ...
gary
Not to one-up Nick but we never even clamp them together. We one or up to a handfull and hold them together until the hold down rollers get them and let them go.
10/16/22       #5: Edge sanding on wide belt? ...
Sean Kovacs  Member
Im curious to know how your Kundig sander is holding up and how old it is? Im a Kundig Dealer in Canada.
11/18/22       #7: Edge sanding on wide belt? ...
Rodney Member
dont do it get a planer, first time somone send's a board thru that is too wide it will chew up your contact roller and will cost you thousand's to fix, we did 1 time when our planer was down, one of my employee's destroyed a contact rooler on an almost new sander... sick feeling.
    • J&P Machines
    • CabMaster Software
    • Lignomat
