Used HolzHers: Glu-Jet vs. Granu-Press
2/7/23
Ryan
Low volume shop in the market for a used bander and looking for advice. Require pre-mill. Prefer a corner round too, but not mandatory. Mostly running 0.5 to 2mm pvc/abs on melamine or pre-finished. Sometimes 1.5-2mm wood on veneer panels. Usually 19-25mm thickness, but occasionally up to 50.
I have used SCM, Format, and HolzHer. The Holzher I used was a 1054 from around 2016. I liked the Glue-Jet better than the other pot systems. The quick heat up and low maintenance are valuable in a small shop with only a couple people.
In the used market (at a price point under $25k) I don't see many desirable Holzhers, but I see a ton of Brandts. I know Brandt has a great reputation, but I'm not interested in the time lost cleaning a glue pot, if we can avoid it. The Holzhers tend to be too old (pre-2004), without pre-mill, or fairly new (post-2016) with price tags usually well over $50k.
There are a couple HolzHer Triathlons (1487/88) on the market (2004/5 - see link). They list the Granu-Press glue system which I have not used. I think it's a vertical hopper that feeds granulated pellets into a similar heating element as the Glue-Jet... can someone verify and help me understand the differences between the two?
Will cartridges also work with the Granu-Press, or is it strictly granulated?
Are the heating and mechanical elements of the nozzle delivery the same in both systems?
Is Granu-Press also highly reliable and low maintenance?
Is there any reason Granu-Press is not a good choice for a low volume custom shop?
https://https://www.machinio.com/?location=&page=2&search=edgebander#quickview/77775043
2/8/23       #2: Used HolzHers: Glu-Jet vs. Granu-Pr ...
Gregory Fasolt Member
Try contacting HolzHer support for comparison between the two systems. I've always found them very helpful. I've only ever had the glue jet and one glue pot. For a smaller custom shop, I would pick the glue jet every time and would pay more to have it, too.
