Building a vanity sink in corner
4/13/23
andrew mcintyre Member
I am building a bathroom vanity in the corner of the powder room.
I purchased a precut quartz top 25" wide x 22" deep with a sink already install. The base cabinet will sit flush with the wall in the corner. I want a 1 1/2" countertop overhang on the front and left side and the right and back side of the counter will be flush with the wall.
My question is if I build the box vanity, to fit with the described length above, will by sink be off-center from the cabinet below- Or will I need to cut the quartz top on the left side 1 1/2" so everything is centered? Sorry I may be overthinking this
4/13/23       #2: Building a vanity sink in corner ...
Andrew McIntyre Member
Actually Wouldnt I remove 1 1/2" of the quartz on the right side and make sure if wall is not square
4/14/23       #3: Building a vanity sink in corner ...
Josh Koschak
1-1/2" overhang on the side is excessive, maybe go with 1/2" there.
Have a wider stile on the right hand side, that way you can center the sink on your cross rail.
    • GreCon
    • CP Adhesives
    • Cabinet Pro
    • Palmetto Cabinet Doors
    • Anver Corporation
