Primer for cabinetry
4/17/23
Vincent
Website: http:// www.improvewood.com
Wanted to know more about laminate cabinets.. I am also interested in knowing the best type of primer to use on these types of cabinets. Thanks
4/17/23       #2: Primer for cabinetry ...
Dave Edgerton  Member
Hi Vincent can you be more specific with your question?
4/17/23       #3: Primer for cabinetry ...
Chippy1987 Member
The bonding of paint to the cabinet might be hampered if the laminate is damaged, deformed, or flaking. Also give it a light sand before applying any bonding primer. Try STIX Bonding Primer or BIN Shellac Based Primer.
4/23/23       #4: Primer for cabinetry ...
Clean it well with diluted simple green then denatured alcohol to remove any gunk. Scuff sand with 240 grit. Prime with BIN.
    • J&P Machines
    • CabMaster Software
    • Lignomat
