Mechanical Fastner
4/19/23
Brian A Franco Member
Website: http://iwswoodworking.com
We are working on a 4" thick slab bartop and looking for ideas on what type of mechanical fasteners to use to pull the sections together. We typically use KV rail bolts but the 4" thickness wouldn't be deep enough to close the top.
Thanks for any suggestions.
Brian
4/19/23       #2: Mechanical Fastner ...
Not exactly sure what a rail bolt is. I assume Knape and Vogt.
I used these for a 1 3/4" thick slab that needed to be joined in the field and they worked out nicely. If you drilled the holes deep enough you could stack two of them, tightening the top one first and the bottom one last.
Zipbolt
Product №: 423510500
Zipbolt Universal Tool 10.500 - 81 mm x 35 mm
4/20/23       #3: Mechanical Fastner ...
Chris Member
We are using Zipbolt's 10.700. Allows us to really bury the fastener deep into the 2" slab closer to the top exposed surface. Rail fastener is great for pulling together staircase parts, Post and Rail for instance.
4/21/23       #4: Mechanical Fastner ...
Chris Hofmann
Website: https://www.csaw.com/p-system/
Lamello Clamex P connectors are an excellent countertop connector, and you can simply create an offset web pattern to the slots (high and low) to span the thickness of your material. Below is a link to an Instagram post of a customer using them for this application:
https://www.instagram.com/p/B5aPL_ohSVb/
