Shelf pin holes
5/26/23
Mark
I recently purchased a used 13 spindle line drill to drill our shelf pin holes. I bought new bits for it and bored the panels for a small job. I have since discoverer that my shelf pins (5mm, metal pin) do not fit. The holes, though clean and consistent, are too large. I checked the bits and they are 5.18mm. The old bits also measure that same diameter. The shelf pins measure 4.95. I've used these pins for several years and never had a problem, although we previously bored using a few different methods/jigs. Has anyone else had a similar problem? Is it runout in the drill? The drill is not that old, doesn't sound bad, and I can't see any visible vibration. It is all the holes also, not just some.
Next question-any suggestions on fixing what is already bored? Is it possible to find pins that are larger, but not full 1/4"?
5/26/23       #2: Shelf pin holes ...
Matt Calnen
It could just be the batch of pins that you got are slightly smaller. I have noticed variations from time to time.
The 5 mm L shaped ones from Richelieu have a thicker neck on them that might help you out of this problem. They are tough to push back tight into the hole. I do not like the looks of them, but they are a lot stronger than spoon type pins. The only downfall is they need more side to side clearance so you might have to trim your shelves alittle.
5/27/23       #3: Shelf pin holes ...
Dave Edgerton  Member
What brand of bits and what brand of pin?
5/27/23       #4: Shelf pin holes ...
Chris Member
Same here, getting a batch of pins that are slightly smaller does happen. We use a CNC so I know it's not us.
5/27/23       #5: Shelf pin holes ...
Shouldn't a 5mm drill make a 5mm hole so the 4.95mm pin fits nice? I know my 1/4" pins are .245"
5/31/23       #6: Shelf pin holes ...
Try running a bit in a drill press and check the fit. A 5mm drill should give you a 5mm hole plus a small tolerance. I suspect you may have one or two spindles that have wobble and are vibrating the board or head causing the oversized holes. Visually check for run out on each spindle, thoroughly clean each spindle bore. Is there side play to any of them?
5/31/23       #7: Shelf pin holes ...
Robert
Tom-I did check the spindles by eye, and by feeling for slop, but honestly couldn't tell. Good idea about the drill press, and the vibration. I looked at the gears and blew out any dust. Should they be greased, or will that just draw in the dust?
Like I originally said, the bits actually measured from 5.08-5.19. Just as an experiment, I ground several of the old bits, sharpening them in the process actually, they drilled fine now. I checked my pins on some older work, and some older pins, and they're all consistent. It's gotta be runout/vibration. If the ground bits work, I'll do that til I find an upgrade. I've used older Delta 13 spindles, as well as one older pneumatic model and never saw this so I'm gonna assume it's just a lower end machine problem. Thanks for all responses, they are appreciated.
5/31/23       #8: Shelf pin holes ...
Thomas Gardiner
Yes, all the multi-spindle gear boxes I have opened have been greased.
My bits (FS Tools) read nuts on 5.00.
6/1/23       #9: Shelf pin holes ...
Thomas Gardiner
Send back the bits. They are most likely the cause. They should measure 5mm
6/1/23       #10: Shelf pin holes ...
deily
I think your case is quite rare
6/1/23       #11: Shelf pin holes ...
Nowkery
10/27/23       #12: Shelf pin holes ...
Brendol  Member
Website: https://www.houzz.com/pro/brendol-scholz/creative-...
I just checked our 5mm bits and they are exactly 5mm.
