Door set back from face frame?
6/29/23
Pete  Member
Hi,
In a Kitchen we are drafting, the designer has requested we step all the doors and drawer faces back from the front of the face frame by about 3/16".
I have never seen this before... is it even possible?
The hinges are a paumelle type, similar to an olive knuckle but rectangular. The hinges are cabinet sized hinges 4" x 2".
My concern is that if both hinge leaves are equal, how can this be done?
Thanks for any insight or help!
Pete
View higher quality, full size image (673 X 258)
6/29/23       #2: Door set back from face frame? ...
Pete  Member
Butt Hinges
Inset Doors
Face Frame Cabinets
White Oak
6/29/23       #3: Door set back from face frame? ...
Matt Calnen
Should as simple as adding a 3/16” shim to the front edge of your mortise jig. The leaves will be the same length. The only issue I can see is you have to make sure the hinge screw holes are located so they are not too close to the face of the door or the backside of the face frame.
To make life easier, I would extend the thickness of the face frame so it is flush, or slightly behind the backside of the door.
6/29/23       #4: Door set back from face frame? ...
Been a while, but I've recessed doors before.
Pretty sure the blum hinge I use would clear fine when fully open, but I haven't verified that.
I don't see a reason to make the face frames thicker than the door. Just move your hinge plates back the inset amount. Also account for it on any shelves behind doors.
6/29/23       #5: Door set back from face frame? ...
Make the face frame 3/16" thicker so the backs are aligned. Then base the hinge offset from the rear instead of from the front. Give the knuckle enough room in the front so the door can swing properly. Wide doors might need a bevel so they aren't to close when operating.
I did a job similar but the inside edge of the FF had a profile. I used Blum hinges for the job also.
6/29/23       #6: Door set back from face frame? ...
You should do a mock up for the designer to show them how much of the hinge leaf will stand out on the door. Hope the customer doesn't have kids, because that kind of inset will be a regular catch basin for spills and food particles.
6/29/23       #7: Door set back from face frame? ...
Matt Calne
Karl, I make the face frame thicker than my doors so I have room for a cabinet bumper behind. I also hold the sides, and bottom of the cabinet in 3/8” of an inch to stop the doors and drawer fronts, and to give a nice custom look.
Leo, wider doors need less bevel, as the swing arc is less. It’s the thicker and narrower ones that need more bevel. The style of hinge he is using will require more of a bevel as the pivot point projects out more than a standard butt hinge. Good idea to reference off the back side if there is not a gap behind the door.
Rich, if a person is having this fancy of a cabinet made, I would assume they have someone to clean their kitchen for them. The hinge projection is an annoying pain, but it seems popular lately.
7/1/23       #8: Door set back from face frame? ...
Al
If you glue 1/8” thick piece to stile that is inline with face of door the space created is where barrel of hinge would be. Think of an interior door with jamb. The barrel does not stick way out. I know because I made my interior doors this way. My trim is 3/4” square edge and barrel only sticks past 1/4”.
There is usually real good money in cabinetry projects like this. Some want the butt hinges and will pay for it.
    • Better Vacuum Cups, Inc.
    • Biesse America
    • CP Adhesives
    • Impact Search and Placement
    • Template Services
