what Blade RPM
8/15/23
Warren E Member
using this new to me SCM saw and blade speed was set on 4,500 from last owner no blade on it I suspect he had a 12 and im running 14"
at the 4,500.and new to me ply offshore sadly had a lot of pitch build up from the ply or glue I guess. stuff is aligned fine, The material outside edge not straight of course but worst I've ever seen, used my straight edge. I'm pretty sure there is tension in this stuff and some movement on the next rip depending on width
Cross cutting its cuts like a razor can hardly hear the blade cut. Should I drop the speed for a 14" blade, Royce blade around 100 teeth maybe not sure what tooth profile would have to go check.
thanks w
8/16/23       #2: what Blade RPM ...
I'd call Royce. They know what the blade was made for and how it was tensioned.
8/16/23       #3: what Blade RPM ...
Warren E Member
I did and have some info but still not answered, emails back and forth. Im looking to guys and what they run they also sent some info on blade sprays they sell
after many years on cabinet saws this new to me with larger blade and choice of RPM. Same time materials have changed and its likely part of it do realize the saw had 12" on it and set on 4,500 RPM. ILl try cutting some old baltic here see how that is and maybe next time try Garniga and see how that builds on the blade compared. I know more about the blade at this point but still not sure if that is the right RPM or need to drop it down max on the blade is 5,200 I did save some charts and saw one that said for 14: keep it down under 4000 RPM then others that contradicted that. thanks w
8/16/23       #4: what Blade RPM ...
Freud says 3,000 to 5,500 on 14" blades.
    • J&P Machines
    • CabMaster Software
    • Lignomat
